Wildfire 5.0 anoying Retrieval window
StuartPonting
I have started using Wildfire 5.o after using every version of Pro-E since 1995. I have started getting a Retrieval error screeen every time I load,save export a file which states:-
anonymous wrote:
You have insufficient disk space for retrieval files to be recorded at the location specified in the configuration option : last_session_directory_path To set a different location for the retrieval files, click close, or make space available and then click Retry.
7 REPLIES 7
I have just loaded wildfire 5.0 and I am getting same problem.
I still havent sorted this issue dowes anybody have any ideas
Stuart,
Did you ever get a fix for this error
John Garvey
John,
I solved this issue on my PC. I just turned off this option in the config file. (last_session_retrieval no).Problem solved.
Paul.
Stuart,
I have never met this message. I guess it is caused by improper permissions somewhere in your user profile.
Martin
Martin Hanák
