Wrapping text around a cylindrical protrusion and then cutting
NEALROSENBLUM
All,
I just wrapped some text around a cylindrical protrusion. I now want to create a recessed cut, and I want the cut to essentially be radial from the center of the cylindrical protrusion. The cylinder is approximately 1.5" in diameter, and I just want to create text that is recessed approximately .020" into the outer surface of the cylinder.
How do you do this? I do not want to project the text along a straight line. It must be radial.
Sincerely,
Neal Rosenblum
Geometrix Engineering, Inc.
201 N. 13th Avenue
Hollywood, FL 33019
Ph: 954-920-2049
Fax: 954-920-9574
Cell: 954-649-9399
<u>neal@geometrixeng.c</u>
Use the surface offset w/ draft feature. Select normal to side surface in the option menu.
Patrick Fariello
[cid:image005.jpg@01CA4CAF.FABBF450] [cid:image006.jpg@01CA4CAF.FABBF450]
