Hi i'm real new to Pro-E and i'm struggling big time, i have created an Asm of an electrical cubicle(call it asm1)which consists of an Asm for the body, asm for the top door,asm = middle door and asm = bottom door this model is fine. I now want to copy this and re-name it to(asm2)and delete the bottom door asm then create a new bottom door asm.When i do this i notice the first assembly(asm1)now has the new bottom door why is this? can you copy asm's and delete/ add new asm's without altering the original that was copied? hope this makes sense as im going mad here many thanks
