We are troubleshooting an issue impacting community login, and it may be intermittently unavailable. Sorry for any inconvenience.
Hi guys I'm trying to sweep pipe in trajectory like in the picture but I't doesn't work. It shows: "Select any number of chains as trajectories to drag."
Idk what to do, maybe I'm doing something wrong. Imake a trajectory like in yt tourial Pipe using intersection in Creo 2.0 - YouTube but it doesnt work. Can someone help me with that?
Appears you have a couple of sharp bend in your trajectory. The trajectory need to be tangent through out. A small radius will also cause problems with larger diameter pipes.
actually i cannot sketch any type of pipe...
I assume you are trying for this:
Have you clicked on the sketch icon and created the cross section?
yep but It doesn't work. I did this in that way: I sketch one side on FRONT and extrude drawing with sufrace to my dimension and then sketch letter U on the TOP and then I clicked intersect. But the better way to do that was your way. Devide pipe in a half . Do like guy in a movie and then simply make mirror. Thanks a lot Kevin for your help
you must first give sufficient radius in the sketch to make the sweep, otherwise you will not sweep you need (being a tube you want to perform).
I now see your problem. You are following a tutorial for a varied cross section and have selected the button for that. You need to create a constant cross section by selecting the other button.
It should extrude for you, but will have a sharp corner with the sharp bend in your sketch.
A sharp bend will extrude, but a radius smaller than the external radius of the cross section will not.
