hello people
i want to make dimenion style as default
how i do this?
i search in configuration editor but i do not discover anything like
tks
other thing is how i control dimension for arrow , i want to make arrow little and i do not how i do
*.DTL config option + my settings, that can helps you:
1) Arrows:
draw_arrow_length 3.500000
draw_arrow_width 1.500000
arrow_style FILLED
2) Text
text_height 2.2
text_thickness 0.000000
text_width_factor 0.6
dim_text_gap 1.000000
3) Font
default_font calibri.ttf
You want to set default_font to ttf in your .dtl file and set the font to what you like.
Or you can change it manually within your drawing.
1) Arrows:
arrow_style FILLED
2) Text
text_height 2.2
3) Font
Did this answer your question and fix the issue?
unfortunately i do not succed
i modify in iso.dtl fille what millan bonka settings but nothing not happened
in config.pro i have good path
i you understand i want orientation (in picture) paralel to and above leader as default
ok topic it is closed thanks
must to open with default and template
sorry and thanks for all
