When opening a standard part file (typically in .step or .iges format), the system should ask for the supplier's name. We would like to have a drop-down list . This supplier information should then be linked to the part's parameters
Common supplier list
Festo
SMC
Emc
Misumi
Schunk
Schmalz
ABB
Other(manually edit)
By the way, you can bring all your ideas here - "Creo Parametric Ideas": https://community.ptc.com/t5/Creo-Parametric-Ideas/idb-p/creoparametric
You may also want to follow this discussion about drop down parameters:
