The community will undergo maintenance on October 16th at 10:00 PM PDT and will be unavailable for up to one hour.
"Nigel Hayward" wrote:
Hi Daryl, Not sure if this works for student edition, if your curve has been defined by a datum point array you can export the points to Excel- highlight datum point array in menu bar, edit definition then save the points file. open Excel then browse to the *.pts file and open Nigel
"Joel Cartwright" wrote:
Hello Daryl, What type of Curve do you have? You have diff options depending on what you have to start with. Take care, Joel
