exporting part file as text for recreation
Chris3
PTC says that there isn't a way to do this and there probably isn't but
I was wondering if anyone has thought about it.
Is there a way to export feature history into a text file so it can be
re-created again from a blank start part?
The only thing I can think of is if there was a way to make Pro/E step
through every feature and then you could save the trail file and run
that again. I don't know if there is a way to make Pro/E step through
every feature in such a way that it would record enough information in
the trail file though.
I realize there are UDFs and I could just save a copy but that's not
what I want.
Chris
This communication, including any attachments, consists of non-public
information that is intended solely for use of the individual or entity
to which it is addressed. It is a confidential communication that may
contain information that is proprietary, privileged, export-controlled
and/or exempt from disclosure under applicable U.S. and non-U.S. law.
If the reader is not the intended recipient, or agent responsible for
delivering the message to the intended recipient, please notify the
sender immediately by reply e-mail and delete the communication,
including any attachments, from your system without saving any
information or making any physical copies. Unauthorized use,
dissemination, distribution or copying of this communication, including
any attachments, is strictly prohibited.
4 REPLIES 4
Technically the .prt file is a text file; it can be opened and edited in MS Notepad. I seem to remember back before version 2000 or rev 18 that the syntax was a lot less cryptic when opening in notepad. Since then with all the GUI changes it is not so manageable.
Patrick Fariello
This was doable up to about 2000i or so as I remember.
The file format at about rev 19 was a flat text file that could be
grep'ed and some neat things could be done.
About then Solidworks made a plugin that would rebuild a pro-e file from
this text file and re-create you parts real-time WITH FEATURES. Really
cool to see. Then the DMCA made it a crime to decode the files and PTC
went to an 'encrypted' format.
Christopher F. Gosnell
FPD Company
124 Hidden Valley Road
McMurray, PA 15317
BobFrindt
2-Explorer
(To:Chris3)
You guys export part files for recreation??
I prefer boating, fishing, hiking and camping. But, to each their own I
guess...
Bob Frindt
Sr. Designer
Parker Hannifin Corporation
Parker Aerospace
Gas Turbine Fuel Systems Division
8940 Tyler Boulevard
Mentor, OH 44060 USA
direct (440) 266-2359
cell: (216) 990-8711
fax: (440) 266-2311
www.parker.com
"PLEASE NOTE: The preceding information may be confidential or
privileged. It only should be used or disseminated for the purpose
of conducting business with Parker. If you are not an intended
recipient, please notify the sender by replying to this message and
then delete the information from your system. Thank you for your
cooperation."
mjenkins
(To:Chris3)
Tools>Program>Show Design>Edit> Select and copy all.
Open start part.
Tool>Program>Edit Design>Edit> Paste
Disclaimer: I haven't tried this 😉
In Reply to Chris Rees:
what I want.
Chris
