failed extrude issue
BR_10009637
3-Newcomer
I am using Creo Parametric 4.0 M010
I have a round tube I extrudeded. I did a extrude from a plane to cut a half moon out of the side of the tube. I saved that tube as a copy and changed extrude ones length, now extrude has rebuild errors and I am not sure why. I deletted the extrusion and tryied to recreate and I am unable to get a extrusion to work.
Here are the errors that I faced
feature regeneration failed
StephenW
(To:BR_10009637)
If the extrude is "long" compared to the size of the cut, then it might be an accuracy issue.
You can try changing the accuray of the part under FILE - PREPARE - MODEL PROPERTIES  - Accuracy
Make the accuracy smaller. If it is relative accuracy and a smaller number doesn't work, try changing to absolute accuracy.
StephenW
(To:BR_10009637)
