Is it possible to make a rule (in repeat region) that filters whole subassemblies (including all parts) according ptc_common_name of the subassembly?
thanks in advance.
T.
I would give the subassemblies a ptc_common_name value of something like "filter_me"
then create a filter rule that is asm.mbr.ptc_common_name != *filter_me*
does this sound like somthing that might work for your application?
if not i have a couple more things you could do but they are just a little more in depth.
are the other things in your region parts or are they all subassemblies?
THERE ARE ALSO PARTS IN THE REGION
ok, but will all parts belonging that subassembly be filtered too?
only if they share that same ptc_common_name
ok, thanks
