flatten quilt failed
hhagedorn
Hello PTC Community,
is there any help about my problem?
I want to create a flatten quilt from a copied surface.
Basically it works, yes.
But if I, for example, insert a rounding or chamfer, the flatten quilt fails.
Are there any ideas or solutions for this?
thx in advance
Heiko
9 REPLIES 9
Hi Heiko
what you have is a solid.As far as my knowledge flatten quilt will only work with quilt or surface.
Hi Rohit,
It is correct that the base KE is a solid.
But the surfaces were still copied to continue using it.
Do i understanding something wrong?
By the way, if you delete the round "ERROR_ROUND" KE-ID 6880, then the flatten quilt works fine. But not with the round.
It's me again, .....
The problem is even if the construction is a boundary blend and no solid as the base KE.
sorry for my earlier post as did ot see your part properly.
Yes I believe the round at the corner is the issue.
Right now can't tell why that is so.
ok that round may not be the issue
I think the issue is the second sketch,which is at an angle to the first sketch.
I projected the first sketch on the plane and was able to flatten it.I took your boundary blend part and made the modification.
I think flatten quilt cannot handle that angle between the two sketches.
I have attached the modified part.But I did the changes in Creo 3.0 student edition.
I made the same change to the part in which you have use parallel blend with the round intact and I was able to flatten it.
I have attached that part also.Changes made in Creo 3.0 Student edition.
For your convenience I have attached the step file of the modified part and you can try the flatten quilt yourself.
Hello rrajan,
thanks for your efforts and your quick Support.
Unfortunately I need the angular offset between the sketches.
Is there still nobody who has a solution?
