i installed creo 3.0 trial version , when i tried to make render by using metal texture the metal folder gave me empty folder but when i make browsing without software i find them
set config.pro option
global_appearance_file <file path>
thanks for help ![]()
Did the config option suggested by Ron help you? If yes, please mark that reply as correct answer. If not, add a snapshot of appearance gallery.
i have been a way for two days ,my problem has been solved byRon , Thanks you for your interest
