Mill window surface selection for finish mill
I have a plate with several openings and some angled bosses and radii on it. I created a mill window and used a mill->finish sequence which handled everything well, except it retracts frequently to skip the openings in the part. I made a copy of the surface and removed all of the openings, and redefined the mill window to the copied surface. The problem is the Mill->Finish still sees the original model and not the added surface. Thoughts? (Original part is an iges in case it matters).
Josh
