Hello i want to design a ribbed washer but i don't know how i made this
Please take me sugestions
thanks
hi,
please look at the sample. I did it in Creo 3.0
regards,
gucio
Hello Bogdan,
Are you using Creo, Windchill, or another PTC product?
You have posted your question in the PTC Integrity forums, and there is no truly useful was to design a washer within this product, but I can move the discussion to the appropraite forum, if you let me know which product it is for.
Kael
i use creo
sorry i see as posted in a wrong place
please redirect my post or delete
Hello Bogdan
in the assembly only the compressed state is important (teeth are flat).
I would model the washer with patterned cuts on the outside or patterned cosmetic sketches. Bent teeth will only affect performance.
Reinhard
Hi Bogdan,
Can you describe the geometry in further detail? Are you looking to make a lock washer? Including a photo is often helpful for other users to visualize what you're describing.
For the washer in your photo, I'd suggest creating the ring (extrude a sketch with 2 concentric circles) as the first feature, then create one tooth, and then pattern that tooth around the ring. The tooth will be the only tricky part; you will probably want to use a sweep feature.
hi,
regards,
gucio
