I am crating a hole table, the system automatically creates the hole tag (A1, A2....B1, B2....), the holes are close together so they are on top of one another, I move them to a readable position. If I update the table they go back to the original position (on top of one another).
Is there a way to make them stay in the position that I want?
Can I create a leader pointing to the hole?
Tom,
I am using Creo/Pro 5.0 Date Code M130, and when I update my hole table, the tags did not move from the locations I had placed them. It only added then new holes that were created. I had to place some of the new tags on a first update, but on then second update, the original and first update tags remained in their place.
Dale
Dale we are using Creo 1.0 Build m040 and if I update the hole table the they move back to original position. Thanks anyway.
