how to place a GTOL on a hole note
jzhang-3
I make a hole and create Geometric Tolerance in model, such as 3/8-16 UNC -2B TAP THRU 5/16 DRILL (0.257) .0750 - (1) HOLE. I only can put GTOL as a free note in drawing as shown below
Is there a method to place to a hole note directly?
JLG
(To:jzhang-3)
I'm attaching a ppt on how I like to do it -- you add the gtol as a free note but then go back and include it in the thread note.  It's clumsy but it gets the job done.
4 REPLIES 4
grepose
3-Newcomer
(To:jzhang-3)
It looks like you created a note without any &dimension or &ad dimensions. Add a shown dimension or created dimension to your note. Then you can attach the GTOL to that dimension. I suggest adding one of the depth dim's to your note. Could look like: depth &dxxx or &adxxx. Also make sure your Detail Config has "gtol_dim_placement" set to "on_bottom" which is default.
JLG
(To:jzhang-3)
jzhang-3
(To:JLG)
It is a great and best way!!!!
Thank you very much!
apaulsen
8-Gravel
(To:JLG)
Thanks for the tip. Half way there... Creo just needs to finish, polish or look at their competitors more. The dust they were left in has already settled.
