in creo changing unit mm to inch drawing view distorted
AK_10359491
In Creo parametric if I change unit mm to inch in the part file after that if I check that detailing file some view have been distorted, section arrow becomes big and some views are missing.
4 REPLIES 4
Dale_Rosema
(To:AK_10359491)
For us to help you better, can you provide screen shots, attach files?
StephenW
(To:AK_10359491)
I did a quick test. I made a part in inches. I just used random numbers.
I created a drawing, showed the dimensions. I didn't try to make a good drawing,
I then went back to the model, changed the part from inches to mm.
Initially, when I returned to the drawing the views were "small" compared to the original.
I regened the drawing views and all came back as if nothing had changed.
See images.
AK_10359491
(To:StephenW)
Hi Stephen,
Thank you for the quick response on this
For small drawings, it is changing perfectly without any issues but if you have 3 sheets and a detailing file containing 100 annotations and in a sheet, some 4 ya 5 detailed views are there that time some views are distorted so this is how can I resolve.
Dale_Rosema
(To:AK_10359491)
Have you tried closing out of the drawing, clearing memory and then reopening the drawing?
