All sections must contain the same number of entities. If not, you may need to create a blend vertex.
See Help:
Please let me know if this answers your question.
Harald
can you upload your model?
-OR-
Can you publish a picture?
What kind of Creo feature do you use?
What kind of geometry do you want to get? Solid or surface?
I don't know what a limit blend is specifically.
Blends need to have the same number of entities in each section. Were you able to get 2 section blend to work, just rectangle to one with curved edge.
I did a simple blend test, 3 sections, just to verify.
See Help:
Harald
My first thought is that you may need to insure that the origin point in all of sections are where they need to be. If they are randomly on different corners, Creo may be trying an impossible twist,
