Hi
I want to extract in a table all the masses for the parts of a aprox.100 elements assembly but I don't find the right report parameter syntax. The first two columns (report index and assembly.member.name) I managed to input but the mass for the member I cannot get. I've extracted for each element a feature MASS_PROP_1 so I can get the mass if i don't succed in getting the report.
thank you
is that hard to do such a thing?
Try &asm.mbr.pro_mp_mass.
