hello all . i hadd plate ,i want to make 3 bends in differient positions.ihad made two but the last can not exexute till i delete the other bend >please help .see attached files
thanks for your help.check the picture
thanks friend.but after applying bend 1 and bend 3 the position of bend 2 is flat.look at pic below
thanks .i'm trying to do this
Also -I do not honor your friendship. But it is a courtesy
This sequence worked for me:
It's definitely not intuitive...
thank you very much for help
