multi-models drawing template
Dom_CHENTRE
Hi alls,
I'm making some drawing templates for Sheetmetal parts.
So is it possible to prepare templates for having final part on first page and flat pattern on 2nd page (xxx_flat1 instance) ?
If yes, how to do ?
If not, how do you handle this ?
Dominique
mender
(To:Dom_CHENTRE)
Not as such -- instantiating a drawing template is done with exactly one solid model.  You could (albeit with more steps) have two templates, one for the first page, one for the second.  File>New>Drawing twice to make one then the other, and employ [Layout tab] Insert > Import Drawing/Data to merge the second page drawing to the first page drawing.
