hello
i am trying to let wildfire optimize a spring rate with the optimization tool
the problem:
i would like to find a springrate for a mechanism.
a force A is forcing the mechanism to move.
a distance B should be reached.
the tool is optimizing something, but the result are not as expected
i would like to find wildfire a springrate for the force A and distance B
what i did:
i created a meassure for the distance
i created a parameter (feature parameter) for the spring (>spring_stiffness)
i created a paremeter springrate
i created a relation to steer the parameter spring_stiffness. (spring_stiffness:fid_featurenumber=springrate)
i solved the problem by switching to proE2001 mechanika motion.
