I am using Creo Parametric - Release 4.0 (connected) 4.0 M030
I try to open certain .prt files from a customer and it gives message that it " cannot be retrieved.
I try to open an assembly and some ot the .prt files are not visible. the .prt files in the folder that cannot be retrieved.
I talk to the customer and they do not have this problem.
Here are the errors that I faced
" filename" cannot be retrieved.
Its possible the files were made in a newer release of Creo, say Creo 5, 6, 7, 8.
You can open the .prt file with a text editor and just below the header of the file, it will tell you what release and datecode it was saved in.
if you are exchanging data with a customer, then install the same Creo version.
The Creo version is the same. 4.0
Besides the version issue, are all of the customer files in a single folder or do you have your search path set to look in the proper folders for all of the component files.
all the .prt files are in the same folder.
certain files do not load in the assembly.
if I try to load the .prt files that do not open in the assembly individually that is when and i get the "cannot be retrieved".
the funny thing is if I use third party translator they will load.
so that is my work around for now.
I would say you probably need to send the files to PTC. If they are non-proprietary, you could try attaching one to this post and let someone on the forum try. Seems as if there is some sort of corruption.
I guess that problematic parts are not created and saved in Creo. Probably these non-native files are "generated" by some non-Creo software.
