The PTC Community will be on read only status starting March 23rd in preparation for moving our platform to a new provider. Read more here
"Invalid value" error when creating a parameter with a list of restricted values.
MD_10042810
2-Explorer
I am using Creo 9.0.5.0.  Like the title says, I am trying to create a few parameters with a drop-down list of values.  Basically exactly what this video is doing: https://www.youtube.com/watch?v=kzvw8wfwavc
I am getting an "Invalid value" error when I try to create this list and I am not sure why.  What might I be doing wrong?
Matt
Quick video tutorial: How to create drop-down menu for Creo parameters without external file Question: When to use a restricted external file? Answer: When you need to use the same parameter type and the same list of variants for more than one Creo file. This video has been created based on a ...
I got it ...
After defining values on Definition tab you have to switch to General tab and set parameter value in Value field. Only then you can click OK button.
Martin Hanák
2 REPLIES 2
Creo 9.0.2.0 ... I reproduced the problem
Creo 7.0.5.0 ... no problem
Suggestion: Report the problem to PTC Support.
Martin Hanák
I got it ...
Martin Hanák
