"Not defined" Datums points on curve surface (WF 4 build m160)
jgfrankusa
Pro Gurus,
I have a top level assembly where a housing has a curve surface. When I
create datum point on the curve surface, I select two assembly datum planes
in the "offset references" to locate my point horizontally and vertically.
The point snap into either horizontal or vertical datum plane depending on
my pick, the two green handle point disappear, and the box next to the
Datum Plane shows "not defined". Any idea, what I am missing?
Any help is greatly appreciated
0 REPLIES 0
