Hello everyone
I have one quary , suppose i have an assembly containing numbers of components and those components are controlled by pro programming, now if i create new varient of that assembly it is obivious that some component will get suppressed ( as it is controlled by pro programming) now if i do save a backup then all the component with suppressed condition also got saved in new location. Is there any setting for this, that only the resume component will be save in a backup folder with assembly and drawing.
try following procedure:
MH
MH
Thank you martin for your reply it is saving without suppressed part but its reference is present in assembly when i make the assy in resume mode it is asking for retrive the component is there any option to auto delete suppress component in assy...
unfortunately I do not know how to automatically delete components suppressed via Pro/PROGRAM.
MH
