"Roeland Toonders" wrote:
Make it a sheet metal model by: applications - sheetmetal And convert with "driving sft" (the outer surface for example) The create a rip insert - shape - rip - regular rip note: If the default datums are in the center of the cone, use these to place the rip To unbend assign the edge of the rip as the fixed geometry Now you should have a flat 😉
