the script language"SELECTION_ON_POSITIVE_SIDE"
伟曹
may i have a question about "
may i have a question about some script language,
I study and look all tab files and find two places ;
FIRST: \afx\parts\connectors\steel_construction_mm\no_standard\i_beam_side_bracket.tab
SECOND: \afx\parts\connectors\steel_construction_mm\no_standard\i_beam_side_bracket_mate.tab
SEARCH_PROF_PERPEND_DATUM I_PROF_SIDE I_PROF_PERPEND_DATUM
IF_25 SELECTION_ON_POSITIVE_SIDE I_PROF_SIDE I_PROF_PERPEND_DATUM
  IF_251 NORM_VECS_LEFT_HAND_CSYS I_PROF_SIDE PLACEMENT_PLANE I_PROF_PERPEND_DATUM
     COPY_REF LASCHE_XY LASCHE_MINUS_XY
  END_IF_251
END_IF_25
IF_26 SELECTION_ON_NEGATIVE_SIDE I_PROF_SIDE I_PROF_PERPEND_DATUM
  IF_261 NORM_VECS_RIGHT_HAND_CSYS I_PROF_SIDE PLACEMENT_PLANE I_PROF_PERPEND_DATUM
  END_IF_261
END_IF_26
I don't understand this script language(SELECTION_ON_NEGATIVE_SIDE and NORM_VECS_RIGHT_HAND_CSYS ) ,can you explain these for me?
For example:    SEARCH_MDL_REF Model Filter Name Variable
Model = "Model name" | THIS | THIS_# | ASSEMBLY
--> Model name = can be defined through USER_SELECT by entering the chosen variable
--> # = Component ID (Only in assemblies)
Filter = SURFACE | EDGE | PLANE | AXIS | POINT | CSYS | QUILT
NAME = "Feature name" (Name of the feature, e.g. DTM1)
who can help me!!
Thanks!!!
hi 伟 曹‌,
here the explanation:
Selection Side
To determine the selected side you can use the commands:
IF_@ SELECTION_ON_POSITIVE_SIDE Reference1 Reference2
OR
IF_@ SELECTION_ON_NEGATIVE Reference1 Reference2
END_IF_@
Reference1 = "Name of the first reference"  (Pick position via a USER_SELECT)
Reference2 = "Name of 2nd reference" (Should be a datum plane or plane surface)
@ = increasing number
For better understanding see also the image below:
Csys Orientation
To determine the orientation of a Csys use the following commands:
IF_@ NORM_VECS_RIGHT_HAND_CSYS Reference1 Reference2 Reference3
OR
IF_@ NORM_VECS_LEFT_HAND_CSYS Reference1 Reference2 Reference3
END_IF_@
Reference1 = "Name of 1st reference" (Should be a datum plane or plane surface = X reference)
Reference2 = "Name of 2nd reference" (Should be a datum plane or plane surface = Y reference)
Reference3 = "Name of 3rd reference" (Should be a datum plane or plane surface = Z reference)
For better understanding see image below:
I hope that helps.
Greetings Sam
Samuel Brantner
B&W Software GmbH
