when i call a part (mmns) through merge inheritance in part window (inches) it fails.
Rohit,
I guess that the accuracy is the source of the problem. Try to play with accuracy values, you can also set Absolute accuracy instead of Relative.
Martin Hanak
The absolute accuracy of the master model and the model that uses it has to be the same. You can change the accuracy of something by picking another model, or type in the value manually to be the same.
However, before you can even use absolute accuracy, the config.pro option to allow absolute accurace must be set as follows (you could cut&paste this): enable_absolute_accuracy yes
Best of luck!
