whole working directory got corrupted.
rohit_rajan
I tried to create a drawing pdf and it showed an error that the pdf cannot be created and then the drawing and its part got corrupt.
Creo gives a message cannot retrieve the file.
the computer I am using is in network.
Has anybody faced this issue before?
Operating system windows 7 professional sp1
Creo Parametric 2.0 M100
8 REPLIES 8
Can you open an older iteration?  If you haven't purged your directory, you should have several iterations available.  On rare occasions I have seen this, usually when Creo crashes during a save operation.  I've always been able to open a previous iteration, however.
LinkedIn
unfortunately i did purge the directory
Ugh, that's a shame.  If you have maintenance, I'd send it to PTC.  They may be able to recover it.
LinkedIn
in my 8 years on proe this was my first time of a corrupt file.
StephenW
(To:rohit_rajan)
If you have maintenance, PTC can sometimes "fix" corrupted files.
You may also try copying the entire contents of the folder to a local directory (preferably on a different computer) and try again just to rule out network issues and issue on your local computer.
rohit_rajan
(To:StephenW)
Hi Stephen,
no we do not have maintenance as of now, in any case we could not have submitted the file because of NDA with the client.
yes i did check it locally on another system and it could not be opened.
are you using a pdm like windchill or intralink?
If so, do you know where your cache files are?
No we are not using windchill or intralink
