IsoDraw 7.3 m30 can you set opacity on a ai file that is placed
bfriesen
18-Opal
I have an ai file that I have placed onto an IsoDraw template. I have ungrouped it so I can select the objects. Is there a way to change the opactiy of one of the objects?
Bryon
1 REPLY 1
mbalko
2-Explorer
(To:bfriesen)
Unfortunately, you can change the opacity in IsoDraw neither on lines nor on fillings. Sometimes it would be useful.
If it's really important, I try elaborate tricks: I change the bottom elements on a light gray. After that I set them on at a higher level. Then it looks like as if the opacity is lower.
Best regards
