Hello All.
I recently started working on CreoView and after having moved from Solidworks, I am unable to use shortcuts for viewing objects quickly such as (ctrl+1,2,3...) for viewing the model in different orientations. Can anyone please tell me how to use these shortcuts to improve the productivity
Here is a link to the keyboard shortcuts documentation:
This should help.
Thank you very much for the reply @agarland
But I am not able to access the link that you have pasted. Can you send it again.
Apologies, pasted the wrong link!
This one should work:
Keyboard Shortcuts for MCAD (ptc.com)
Thank you very much @agarland . I have more doubt. These standard orientations are actually not exactly the same when compared to the views as obtained from the drawings, as my team have used different planes . So for Example, I would define/customize a new view and type in the co-ordinates such that it becomes the exact front view when compared to the real physical part. Now for this new view, how can I add the new shortcuts such as K,B,N. as shown in the image . I am unable to do this and this is mostly what I require. Thank you in advance. I have been searching this for a long time now.
You can customize the existing orientations:
Thank you very much for the reply and your efforts @agarland . So what I can do is that I will put in the correct co-ordinates to Top, Bottom, Front, etc so that instead of creating a new orientation, I will plug the values to these and use the shortcuts to view them quickly. Ok got it. Thanks a lot
