3D Box End Wrench
jlippeth
3D Box End Wrench
Anyone have a 3D model of a 1 ½" box end wrench?
Or combo, open end / box end
Jeff
<jscott>
This email may contain material that is confidential, privileged and/or attorney work product for the sole use of the intended recipient. Any review, reliance or distribution by others or forwarding without express permission is strictly prohibited. If you are not the intended recipient, please contact the sender and delete all copies.
rrich
2-Explorer
(To:jlippeth)
You can find some here
Thanks Ron
They have many to pick from, I found my size
JScott
Jeff Lippeth ▪ Mold Design Engineer▪ NyproMold▪ P 847.855.2226
I have a part that uses a family table to represent the flat pattern.
When I use "Save a Copy " and check copy drawings every thing works
nicely except in the new drawing the flat pattern view references the
instance from the old part. The new copy of the part has no family
table. That's easy enough to recreate (one feature parameter yes/no)
but you can't "replace" a model in a drawing view unless it's from the
same family table. Did I miss something easy?
Bernie Hayden
The information contained in this e-mail message may be privileged, confidential and protected from disclosure. If you are not the intended recipient, any dissemination, distribution or copying is strictly prohibited. If you think that you have received this e-mail message in error, please e-mail the sender at the above e-mail address.
