Add a wizard into Creo Flow Analysis
bduncan
7 REPLIES 7
Check this picture. It should be implemented in Creo 6 (maybe 6.0.1.0.)
Software consultant.
Thanks a lot,would you share the document?
Wizard tool is not available in Creo 6.0.1.0 yet, the plan is adding it into Creo 6.0.2.0
Don`t see it in 6.0.2.0 either.
It is possible in Creo 6.0.2.0. , but you need a special update Simerics file.
Please wait for Creo 6.0.3.0 or contact PTC support.
Refer to technical article https://www.ptc.com/en/support/article?n=CS311282,
Flow analysis Wizard will be added into Creo 4.0 M120 and Creo 6.0.3.0
