Hello everyone,
I recently ran a sensitivity study with 20N load applied on the model from 0° to 360° from the start position thanks to user skunks's help! I also defined many points to obtain the strain values from the study. I am wondering if anyone knows
1) if I can export the measurements in the .csv like what a static analysis do?
2) Can I create a parameter relation feature in Creo with the user-defined measurements? And then have Creo plot the final results vs. angle?
Thank you so much!
