Hi all, I am trying to design a wind turbine blade through using multiple sections (around 40) by using the swept blend feature, however this does not seem to work. When I try to use sweep blending it simply says the model failed to regenerate, yet when I use the surface blending function the model generates just fine. Can anyone help?
Amin
Ambiguious question. Try using the surfaces, then solidify?
Sounds like overlapping issue.
Are you sure start points and directions of each section match the others?
