Creo Ansys Simulation does not run
dreamless
Creo Ansys Simulation 不运行
I met the same problem in Creo 9.0 and Creo 10.0. In Creo 8.0 and Creo 7.0 analysis runs well.
I am almost sure that your computer contains AMD CPU. Is it true ?
If you have Commercial license then report the problem to PTC Support.
Martin Hanák
dreamless
(To:MartinHanak)
AMD  CPU
if you have Commercial license then report the problem to PTC Support.
Martin Hanák
