If you're using a fluid domain that was created with Creo Flow Analysis, you need to use the Project > Update Project command in the ribbon. This will regenerate the fluid domain geometry and run the mesh while preserving all of your project settings.
Just using Generate Mesh only works if you are modifying a hand-created fluid domain part.
Thanks, but no, even if I use 'Update Project', the mesh doesn't update.
When you say there's a difference between a domain that was created in Creo Flow and a 'hand crafted' one, what do you mean? If I open a simple pipe in CreoFlow, I can use 'select simulation domain', then 'add fluid domain', and select the cylinder. Or, I can use 'Create fluid domain' option.
Do those 2 operations not end up with the same domain?
