I have been trying to use Creo Simulate Live, just to see how it works, but when I start a simulation, I don’t get any results (see picture below). I tried running the same setup in Creo Simulation and got it to display results in there. Am I missing something in Creo Simulate Live to show me the correct results?
I used a load of 25lbf down on the top, and fixed the bottom surface.
I had to add 2 folders on my computer to get it to work when I first used Simulate Live:
I can't find the original documentation I received to add these folders, but as I remember, one of the folders is needed for it to work.
Here is the article referring to the issue I had - https://www.ptc.com/en/support/article/CS305968
(referred to in the article referred to by ghunsinger)
Hi @ghunsinger,
This is an known issue.
Please refer existing article https://www.ptc.com/en/support/article/CS311463 for troubleshooting steps.
Rahul
