HI,
I'm new here, this is a simple example,Detailed setup as blow, the mesh genration the inflow boundary condition is 0.3m/s
and the outflow boundary condition is
and click Run icon, For a little while ,the soft pop up the dialogue box,
What am I supposed to do? I'll uploap the files,Creo 4.0.Thanks in advance!
I had to solve the same error yesterday. It was caused by NON-ASCII characters at the path to the working directory.
It seems, that Creo CFD module doesn’t support “Unicode” fully.
PZ
(probably this is not up to date reply, but it could be useful for someone else…)
PZ
YES,I have solve this problem BTW,Did YOU INSTALL CREO 6.0.1.0?
Yes, I've solved this issue just for 6.0.1.0...
will you see knob "Wizard" Interface of Flow Analysis?in creo 6.0.1.0?or would you show me the picture that include "Wizard"
Unfortunately no, I’m convinced that 6.0.1.0 still has no Wizard dialog released.
(There is resource file for dialog at installation, but there is no gui access to call him from the Creo Flow Analysis dashboard.)
Thanks,maybe will release it in the future version.
