How to Save a Static FEA Animation
nebraska-engr
I am trying to save the animated result of a static simulation. Every website, including PTC, says to select "Movie" from the "Save As" menu. I do not see this option. How do I save/export FEA results in Creo 5?
I am using Creo 5.0.4.0 on Windows 7.
skunks
(To:nebraska-engr)
maybe windchill conflict,
please test without windchill
23 REPLIES 23
It is not called movie but the extension is .mpg.  It is called TLBMPEG
Here is a mapkey I use that you can add to your config file in your startup folder.
Be sure to have the first frame showing before starting and have 24 frames in the animation.
I also try to set the window size smaller than my screen with close to the proper aspect ratio before running the mapkey.  (helps with text size and aspect ratio issues)
You can customize the mapkey to your preferences.  The first 24 is the frames per second and the second the number of frames.  The 480 and 720 are the size in pixels.
It saves a file in your current directory that you need to rename before running the mapkey again or it will overwrite.
mapkey mpg @MAPKEY_LABELmpg movie;~ Select `main_dlg_cur` `appl_casc`;\
mapkey(continued) ~ Close `main_dlg_cur` `appl_casc`;~ Command `ProCmdMpostSaveAs` ;\
mapkey(continued) ~ Trail `UI Desktop` `UI Desktop` `DLG_PREVIEW_POST` `file_open`;\
mapkey(continued) ~ Open `file_open` `Type`;~ Close `file_open` `Type`;\
mapkey(continued) ~ Select `file_open` `Type` 1 `db_631`;~ Input `file_open` `Inputname` `1`;\
mapkey(continued) ~ Update `file_open` `Inputname` `1`;\
mapkey(continued) ~ Command `ProFileSelPushOpen@context_dlg_open_cmd` ;\
mapkey(continued) ~ Move `mpeg_export_dlg` `mpeg_export_dlg` 2 31.346769 12.647672;\
mapkey(continued) ~ Open `mpeg_export_dlg` `SettingsOption`;\
mapkey(continued) ~ Close `mpeg_export_dlg` `SettingsOption`;\
mapkey(continued) ~ Select `mpeg_export_dlg` `SettingsOption` 1 `custom`;\
mapkey(continued) ~ Open `mpeg_export_dlg` `FPSOption`;~ Close `mpeg_export_dlg` `FPSOption`;\
mapkey(continued) ~ Select `mpeg_export_dlg` `FPSOption` 1 `24`;\
mapkey(continued) ~ Update `mpeg_export_dlg` `HeightSpin` 480;\
mapkey(continued) ~ Update `mpeg_export_dlg` `WidthSpin` 720;\
mapkey(continued) ~ Activate `mpeg_export_dlg` `DurationNumFramesCheck` 1;\
mapkey(continued) ~ Update `mpeg_export_dlg` `DurationNumFramesInput` `24`;\
mapkey(continued) ~ Activate `mpeg_export_dlg` `ExportPush`;
If you check the screenshot I posted, I do not have the option to save as any file type other than simulate results, hence my posting of this question. I have seen on the PTC support site that you should be able to click "Save As" and choose the file type for mpeg, but it doesn't show up.
Creo is a little weird here.  Click the Save As again where I show.
Oh and correction there is a MOVIE option for AVI files.  I just never use that because it is uncompressed.
Maybe what I replied with wasn't quite clear, I have no file type options within "Save As" other than simulate results. See the image.
Did you click again where I show the red circle?  Or were you not replying to my last post.
Yes, when I say that I clicked "Save As" I mean that I clicked "Save As" and was not clicking in the wrong place. I can record a video if you don't believe the screenshot?
Is there any reason why Creo Simulate would not give the option to save as an Mpeg? I used to be able to save my simulate results as videos (mpeg) on Creo 3.0, and after my recent switch to Creo 5.0, the functionality seems to be gone.
I may have to open up a support ticket with PTC. It's funny, seems like every "feature" on Creo is actually nonexistent or doesn't properly work!
Hmmmm.   I will say I do not have windchill option like you have. But since your dialog matches the "Save a Copy" dialog expected I still think the weird click sequence is the issue.
I know this is really weird, I don't know how many times it has fooled me. (too many)
Weird Click sequenceWeird Click sequence
I get the same window with the same options whether I click "Save As" or "Save As > Save a Copy."
Although my "Save As" option only requires one click, and not two. Yours requires two clicks?
I had not considered that this would be "wrong" behavior for Simulate Results. It does seem a little odd...
How about Save As, Save a backup?
Oh I see, it is because I don't have windchill that this is the sequence for me.
Save a backup also has the same two options. The other options for animations, etc. are not shown.
I would contact PTC.  I think it is related to your windchill setup but I have never used windchill.
Last ditch suggestion... Is it possible that you just need to choose a local drive location rather than your workspace and then the new file types show up?
skunks
(To:nebraska-engr)
i use
The built in movie exporter in Creo hasn't been updated since they folded it in decades ago. It is out dated and terrible.
I would suggest looking into screentoGIF. Its open source very easy to use and will get you a lot better result than what Simulate outputs.
https://www.screentogif.com/
Firstly you need to run the animation, and then go to File --> Save As --> Save a Backup and then select the file type to Movie, Thats it!!! Please refer to
FEA Animation.mp4
Video Player is loading.
Current Time 0:00
Duration 0:45
Loaded: 0%
Stream Type LIVE
Remaining Time 0:45
1x
    • Chapters
    • descriptions off, selected
    • captions off, selected
    • default, selected
    (view in My Videos)
    the video attached
    skunks
    (To:Kishore_K)
    Your video doesn't work
    Kishore_K
    (To:skunks)
    Please check now, I have uploaded again!
    TomU
    (To:Kishore_K)
    Videos won't play until a moderator approves them.  Not sure how long that takes...
    skunks
    (To:Kishore_K)
    maybe
    Hey guys, if you take a look at my previous replies and look at the screenshots I have posted, I do not have the video file options within "Save As." They just don't show up. The only option I have is to save it as a results file. Animations/Mpeg/etc. doesn't show up.
    You would find the options under Save As Backup
    No matter how many times I type "I can't see these options," my point doesn't seem to be made.
    Please look at my previous replies and attached screenshots.
    skunks
    (To:nebraska-engr)
