It might be due to :
Suggestions to be tested one by one:
Unfortunately your description would be not enough to narrow the possible problems. Non convergence in LDA can have several reasons, Meshing, material definition, step sizes or even garbage being wrongly included in the model (like corrupted deleted/suppressing features or load/constrains.
Without more details - or the model - it may be hard to get a feedback.
Sometimes for NDA reasons you are not allowed to forward the model - but you can create a dummy (and simply) CAD model that is a copy of of your FEM setup. This will also help you to find if the problem is specifically model related or if it is how you are defining it in Simulate.
