Showing Velocity Values in Flow Analysis
niclas_barth
Is there an option to see exact values of pressure, velocity etc. in Creo 4.0? For example: If I create a monitoring point in a pipe, I would like to see the exact velocity-value "xy" at this point. I just can plot a graph.
My actual goal is to get an average value of an area with different velocities (like shown in the picture). I just have the rough information from the legend.
As far as I know, no. Indeed my organization has already signaled to PTC this (and other) lack. The only workaround is based on to see the colour.
niclas_barth
(To:gfraulini)
Thanks for the response! That's unfortunate. Do you know if there is a possibility to get more accurate data?
I created several monitoring points and can see rough values in the graph. Maybe it is possible to export my graphs to excel to get a more accurate result?
The exportation is another thing we've required to PTC. Maybe with Creo 7 there will be more enhancements (also) on Flow side.
