Simulate Live, Air Flow simulation on imported geometry
JZ_10702753
3-Newcomer
I'm trying to perform an air flow simulation on a part that I imported. I used the import doctor to try to fix the geometry and create a solid. But running the simulation, I think it isn't actually doing anything. It appears as a solid body that's why I thought it would work but apparently no.
tbraxton
22-Sapphire I
(To:JZ_10702753)
Define appears as a solid body? How did you test for solid geometry? You may not have solid geometry in the model. Shaded surfaces can appear solid so seeing a shaded image is not confirmation of solid geometry existence in a model.
If you view the import in wireframe you can tell immediately if it is a solid or not based on your system color assignments.
Involute Development, LLC
Consulting Engineers
cfdgeek
(To:JZ_10702753)
You can try CFA, CFA does not require solid bodies for external flow problems. You can run air around vehicle or aircraft with sheetbodies in CFA
