8-Gravel
July 13, 2023
Representation of Skip weld in shell elements using Perimeter weld (2D Mesh)
  • July 13, 2023
  • 0 replies
  • 1248 views
I want to give skip weld in Creo. If it's solid, then pattern approach will be there. But when it comes to shell perimeter weld. What will be the best and easiest way? My approach is: Creating surface regions and for the small surface edges I will create Perimeter weld, Where this process is tedious to do. Could someone help me with the easiest way.
