Traceback Error
asmith-3
Traceback Error
I have received a fatal error message and Creo says it has created a Traceback. Why did this happen and how do I fix this. I have gotten them before and once I did I was unable to check the model/assembly in. Any fixes for this?
TomU
(To:asmith-3)
TomU
(To:asmith-3)
Pretty much any time Creo crashes or hangs it will automatically create a traceback file. This file can sometimes help tech support in diagnosing the problem. Unless you're interested in creating a support case, you can just ignore it and restart Creo.
gkarigoudar
2-Explorer
(To:TomU)
I also had similar issue, while working with top level assembly, when we switch off layer, Creo will crash with traceback error
StephenW
(To:gkarigoudar)
If this is a consistent, repeatable error, you definitely should open a call with PTC and they should be able to get it fixed.
TomU
(To:asmith-3)
Here is the "official" word from PTC on traceback files:
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS49550
