hello ProE CAM users...
I have recently started using site parameter files.
I´m following the instructions provided in PTCs manual for Pro NC.
So far I have encountered the following problem, every time I select the site file I get the following message, and the milling sequence can not be executed:
warning message: Invalid parameter value USE_SURF_NORMS is found.
why is this parameter so important, why do I need to change it?? In other examples I have not changed this parameter at all, and I have not had any trouble.
please look at the image attached.
thanks, regards
al.
