Arbortext Publishing Engine - Accessing Activation files from network share
MG_7500376
3-Newcomer
As per the original post
Hi Gareth / Vignesh , how did you modify coding related to File object with Perl ? I am facing the similar problem , even not working with mapped drive, but works when files are in C: drive
I think what Vignesh did is to use Perl to access the files, instead of Javascript.
Thanks a lot Gareth, i am not sure what it means, my issue is when topic files are in C: drive and when I publish pdf the bookmap, I can get the reference text generated but when I have the topic files located in mapped drive, reference text don't get generated. attached is the example.
OK, understood, but that is a different issue to this original posting here. If a mapped network drive doesn't fix things, then I would suggest you might need to open a PTC Support case. Unless someone else has a good idea!
Another thing to check is to make sure your file references are relative, and don't include hard-coded paths to C: drive locations. Your href attribute on the xref element should not contain C:\... path information in it. If it does, that would explain why it works on the C: drive but not when you move the files to a different location.
