Associate a stylesheet to ditamaps / topics
bfriesen
18-Opal
We have multiple stylesheets and I would like the default one to be selected when publishing. Currently if I publish a topic by itself it chooses the correct stylesheet. When I publish a map it chooses a different one.
The goal is to have the same stylesheet selected when publishing a topic or a map. I did find a help topic about adding a stylesheet PI https://support.ptc.com/help/arbortext/r8.1.2.0/en/index.html#page/admin%2Fadmin%2Fhelp1394.html  I do not think that is what I want. I also found this one https://www.ptc.com/en/support/article/CS269879?source=search and it does not seem to work.
Currently if I go to format, select stylesheets the editor/default  path is correct to the techinfo stylesheet, but the print/pdf is empty with no association. My guess is that it should be set to the default techinfo stylesheet also. Is that the correct thought? Is there a way to make the setting global for all the users.
Bryon
Thanks to Tim P  @ptc support. This setting is driven by the instance.acl file located in the doctypes directory. I had the instance.acl techinfo file set correctly, but was unaware that the same file existed in the techinfo map folder. Once I modified that file also it worked as expected.
Add the following lines to the instance.acl file. Change the techinfo.style to whatever stylesheet you want to be the default.
set stylesheet=techinfo.style
set printstylesheet=techinfo.style
Bryon
Bryon
