My PTC and associated tools are currently undergoing planned maintenance. This may impact the community, especially login. Pages may become temporarily unavailable, requiring a refresh or resubmission.
Disabling _touchup in specific gentexts
JeffStevenson
Is there a way in FOSI to disable_touchup PIs in specific gentexts? I can disable it in specific contexts, but this disables it across the document. My gentext is coming from a ufe which cannot be used as a context in an e-i-c to my knowledge. Has anyone selectively disabled _touchup PIs in some gentexts by not others?
Thanks!
One of my stylersheets has the following e-i-c in a FOSI edited source:
<e-i-c gi="touchup" context="*" _sfe:headerorfooter&quot;=" gitype="pi">
This is a very, very recently upgraded from 5.3 to 6.0 stylesheet so I
can't comment on how reliable that coding is but it suggests to me you
could probably achieve what I think you're aiming for. (Whether in 6.0 you
have to do it in FOSI edited source is another discussion to have with
someone here who has been there, done that.)
On Wed, Sep 5, 2012 at 8:32 AM, Jeff Stevenson <jstevenson@gpslsolutions.com<br/>> wrote:
> Is there a way in FOSI to disable _touchup PIs in specific gentexts? I
> Thanks!
If you are using Styler, there are checkboxes on the context dialog for
whether you want to include UFEs and/or SFEs in the context hierarchy:
I'm assuming that if you choose that option, and then export the
stylesheet as FOSI, you'll get something that looks like Paul's sample.
(This is with 6.0, M050. Not sure whether this is supported on earlier
versions.)
--C
Clay Helberg
Senior Consultant
TerraXML
Hi Clay,
If I check the boxes, they don't remain checked in the context I'm working in. Do you know why these would uncheck themselves?
-Jeff
Hi Jeff--
As far as I can tell, it only preserves the checks that you actually
use. In other words, if you don't specify a UFE or SFE in the context
selection, it won't keep the corresponding box(es) checked.
Basically, checking the box makes sure the UFE/SFE elements show up in
the droplists that you use to add elements to the context hierarchy, for
as long as the dialog is open.
So I guess you'll just have to manually check the box each time you want
to add a formatting element to the hierarchy. I don't know of a way to
change the default behavior to make them stay checked.
--Clay
Clay Helberg
Senior Consultant
TerraXML
Thanks, Clay! I was able to create the proper context.
